David Brown 995 Hydrolic Problem
James London
03-26-2008 19:14:09
I have a DB 995 and all the front hydrolics work fine...but my rear hydrolics do nothing. They were working about a month ago and I went out one day and they wouldn't do a thing. I have changed the gear oil and no change. I did find some water in the old gear oil...and I think that might have something to do with the problem. My biggest problem is I have no paper work on this tractor and really have no idea where to start. Any ideas or direction to paper work or manuals would be great!!! Thank you!
ArleninOr
03-27-2008 13:35:57
 Re: David Brown 995 Hydrolic Problem in reply to James London, 03-26-2008 19:14:09
James, did you change the filter and clean the accompaning screen? Could be a blockage in the control valve on the rt axle housing is a little plate held on with 2 screws or bolts under that are 2 big screws that have a plunger with a screen in them that sometimes get plugged. Carefully remove one at a time and clean out.Magnetic tip screwdriver works real good for this.
