Hydraulic/Trans fluid
Kevin in Iowa
03-26-2008 05:53:28
On my 830 C.K. I have drained and replaced the hydraulic/transmisson oil a couple of times now and have always used the fluid from the case dealership down the road. Its about $90.00 per 5 gallon I always see 5 gallon buckets of "tractor fluid" at the local auto parts stores. Is that the same stuff? It has to be cheaper then the case stuff.. thanks in advance
Leland
03-27-2008 19:07:20
 Re: Hydraulic/Trans fluid in reply to Kevin in Iowa, 03-26-2008 05:53:28
We used other brands of oil in cases where I worked and always had problems ,stick with hytran from IH may cost a little more but still cheaper than a visit to the dealer for trans work. and the dealer told us to change the filter every 200 hours and this helped a lot as well stopping problems .
mEl
03-28-2008 03:27:48
 Re: Hydraulic/Trans fluid in reply to Leland, 03-27-2008 19:07:20
Leland , you are exactly right, the price of parts and labor far exceeds the extra dollars for a proven product. Sometimes we can't see the forest for the trees in our effort to save a buck. I have been with a Case dealer for 46 and have seen many oil related failures and cringe when I see people recommend oil from "Freddies discount house". mEl
Walt davies
03-26-2008 22:24:49
I get mine at Walmart for around $40 haven't seen any trouble with it yet and I use it for pretty heavy use. Just because it cost more doesn't always make it better. When I had my Service station back in the 60s I charged $0.10 a quart more for Pennsoil I paid the same for it just made more for me and people would swear it was better oil because it cost more. Walt
caseman-d
03-26-2008 19:12:15
Might have to tell the boss to raise his price on our hytran. Think ours run about 55.00 for 5 gl bucket.
caseman-d
Charlie in ME
03-26-2008 10:37:04
I use the VIP HydTran in my '69 580CK and no problems at all (knock on wood). Not heavy use with this machine either. Seems to work. I am too cheap to get the other stuff.
DKase
03-26-2008 10:35:55
I am not a green fan, but I like their bulk hydraulic oil. It is a 20 weight, where the Case Hy Tran is a 10 weight. Seems to hold up better in the hyd. systems that have a little wear in them. DK
Dsundy
03-26-2008 07:31:46
I paid $55 for 5gal of the Napa heavy duty hyd fluid which is their brand of the TCH. Seems to work fine in my 530 although it doesn't get heavy use.
Dan
