Replacement 6 Volt regulator - 47 Case SC
Jason Lembke
03-25-2008 18:33:22
I"m looking for a replacement 6v regulator for my 47 SC. I have the original autolite generator mount.
Anyone had any luck with using a regulator from a similar year Case? Are they interchangeable?
I"ve tried a cut out and would really like a regulator instead.
SDLars
03-26-2008 08:35:24
 Re: Replacement 6 Volt regulator - 47 Case SC in reply to Jason Lembke, 03-25-2008 18:33:22
The 6-volt regulator that most parts stores have listed (T4327E or SI VR224)is on manufacturer's backorder and I've gathered that essentially means they aren't making it anymore. I have had one on order at three different locations for over a year and nothing has shown up yet. I've gotten a couple on Ebay that have worked OK. Here's an outfit that says they can rebuild your old VR and they also have a couple of choices for replacements. They have a US built Autolite T4327E or a Standard Ignition (SI) VR224 for $105 the last time I checked. They also carry an import for $30.Precision Power, Inc., 630 Park Place, Lansing, MI 48912, 800-794-5962. I haven't used them yet but I plan on giving them a try soon. I'd be curious what luck others may have had with them.
Gene Dotson
03-26-2008 02:22:39
You will need a negative ground regulator. The VC uses a positive ground system... Gene
Jason Lembke
03-26-2008 05:59:13
 Re: Replacement 6 Volt regulator - 47 Case SC in reply to Gene Dotson, 03-26-2008 02:22:39
That's good to know...
Are there other Case models that used a negative ground that would be a possible substitute?
Thanks Gene.
Gene Dotson
03-26-2008 06:08:15
 Re: Replacement 6 Volt regulator - 47 Case SC in reply to Jason Lembke, 03-26-2008 05:59:13
Any SC, DC,or LA would work. All tractors made in Racine were negative ground and all made in Rock Island were positive ground... Gene
HossinMe
03-25-2008 18:38:40
NAPA Hoss
Gene Dotson
03-26-2008 06:16:52
 Re: Replacement 6 Volt regulator - 47 Case SC in reply to HossinMe, 03-25-2008 18:38:40
Our NAPA stores here are virtually worthless trying to find tractor parts. Usually get that "Gee, I don't know where to look for that" answer.
I sure do miss the old time independent parts stores who depended on what they sell for their livelihood... Gene
Jason Lembke
03-25-2008 19:23:08
Tried NAPA. They weren't much help. I found a similar regulator for a VC at a local farm store but wasn't sure it would work.
JGarner
03-26-2008 06:18:55
 Re: Replacement 6 Volt regulator - 47 Case SC in reply to Jason Lembke, 03-25-2008 19:23:08
I got my VR and a rebuilt generator for my 630 at Valu-Bilt on line. They work great!!
http://www.valu-bilt.com/
