Case 311-b clutch quesstion
Larry59
03-24-2008 19:51:04
My case is gas driven and the book shows a 9 1/4 " clutch. My question is... Like today I was asked what the spline count on pto is? Wanted to know if it is an 8 count spline. But found mine is a 6 count spline. Seems like it made some kind of difference but I don't understand why? Now they also asked me how many splines on the transmission end? Do not know this cause my tractor is not torn down plus I have to wait and have someone else do that for me. Why these kind of questions? Also was told that a 530 case clutch and pressure plate might work?
Any help on any of this.
Larry59
03-26-2008 20:46:51
 Thanks all for returns info. in reply to Larry59, 03-24-2008 19:51:04
Tractor was picked up today by OLD.. Rich and taken to his home. He split tractor and found clutch was shot clear down to the revits rubbing. Found the one spline to be a 10 count and the other a 24 count spline. Going to see about one getting ordered in morning or Thuresday that is.
Roger300(md)
03-25-2008 04:13:37
 Re: Case 311-b clutch quesstion in reply to Larry59, 03-24-2008 19:51:04
Larry; Are you sure which cluch is slipping, I recently bought a 300 that the owner had replaced the foot clutch but was still not pulling right and slipping. It was the hand clutch that was slipping and that one is easy to adjust once you know how, just a thought Roger
djm75
03-25-2008 03:28:55
on the caseih website it shows 2 different single plate clutches for gas and diesel engines. then there are also double plate clutches that looked totally different appears there are alot of options.
Joe (Wa)
03-25-2008 02:32:55
Larry, as near as I can tell from your post you are looking for a clutch plate and a pressure plate, is that right?
The shaft that drives off the engine clutch plate is called a "clutch shaft" and sometimes a "engine pto shaft". It is splined at the clutch plate and on the other end (transmission end) just aft of the clutch shaft bearing at the hand clutch pack on your tractor.
It appears the vendor is trying to ID the clutch shaft so they can provide a 9-1/4" clutch plate with a spline count & diameter that matches your clutch shaft.
The clutch shaft for the 300B series is p/n G10365 before s/n 6097696 and p/n G17201 s/n 6097696 and after. I think the 9-1/4" single clutch plate (standard p/n G11077 or heavy duty p/n G11079)is the same for both but if the vendor can't figure it out from the shaft p/n's go somewhere else.
The least expensive repair is to reline if your existing plate is in decent shape.
The pressure plate is a different animal, it is splined to accommodate the hydraulic pump drive shaft. I wouldn�t try to do any generic matchup there.
Joe
Jim W.
03-24-2008 22:44:15
The 430 and 530 used a wider bolt pattern on top where the back of the engine bolted to the torque tube allowing for a larger diameter flywheel. I don"t think the 311B and the 430 will interchange, so I know the 530 won"t.
Larry59
03-24-2008 21:45:56
 Valu did not; have the clutch in reply to Larry59, 03-24-2008 19:51:04
Went to web site and none was shown for my tractor the 311-b .. thanks
Jim Bonham
03-24-2008 21:19:52
Go to Valu-bilt.com and get Free Catalog. This place has the clutch you are looking for and can answer your questions about your tractor.
coloken
03-24-2008 21:15:09
I don't have my book here but I remember it showed two diferent size clutches for my 300 round nose Case. Could be the same for the 300B..Case did things like that. You never know til you get it apart.
