830 Case Puller
HossinMe
03-24-2008 16:55:31
Ive got a 830 com dsi Im gonna pull with,should I retard timing as in a gas eng or leave stock?How about torque converter fluid,ATF or the stock hyd fluid? Thanks,Hoss
Jim McVay
03-25-2008 18:03:51
 Re: 830 Case Puller in reply to HossinMe, 03-24-2008 16:55:31
My dad has been using Dextron ATF in his 800 puller for years with good results
dboll
03-25-2008 12:40:26
I use hy-tran in my 1570,830hyds. but I run CASE tch in the case-o-matic just for safe sake though 303 JD/universal trans-draulic should be ok
HossinMe
03-25-2008 05:59:17
Yep,shes a diesel,not a gas burner. Thanx,Hoss
Gene Dotson
03-25-2008 02:48:50
Hoss;
I pulled my 700 diesel for several years. I was able to run the engine at 3200 RPM with 32 degree timing. Stock is about 24 degrees. This is a 267 engine with 284 M&W kit
The tractor in now back in the working category and the timing is still the same and has worked this way for over 25 years at a more reasonable 2200 RPM...
Gene
garytomaszewski
03-24-2008 20:32:46
Don't understand RETARD timing. Try this;with engine idling slowly ADVANCE timing and notice increase in RPM. Rule of thumb; book timing is at sea level and 70 degrees air temp, advance 2 degrees over book per 1000 feet elevation. Burn Aviation premium, and if you can dyno play with ADVANCE for max HP. I use HY-TRAN in the tranny and hydraulics. GOOD LUCK!
mEl
03-25-2008 03:24:13
 Re: 830 Case Puller in reply to garytomaszewski, 03-24-2008 20:32:46
I would not recommend aviation gas for your Diesel engine! The advice to advance the pump timing will help the HP at higher rpm levels. It would be helpful to tune it on a dyno if you can rent one nearby for an hour
