VAC question
old
03-24-2008 14:53:26
Is it a wet or dry sleeve engine. Got one of the 2 I got not long ago to spin over but #3 sleeve came out with the piston so I need to know this info so I know which way to go from here
mEl
03-25-2008 04:18:38
 Re: VAC question in reply to old, 03-24-2008 14:53:26
All Case built water cooled engines except the 164 CID used in the 500-600 B tractors are wet sleeve design. They are sealed on top by the head gasket, and O rings on the sleeve or in the block on the bottom depending on model. mEl
Jim McVay
03-25-2008 18:01:56
 Re: VAC question in reply to mEl, 03-25-2008 04:18:38
They used the 164 in the 351s also
BarryfromIA
03-24-2008 16:32:58
The VAC I have is a wet sleeve engine. It is a 1947 model.
AlexLV
03-24-2008 16:23:08
I'm pretty sure it's a wet sleeve engine.
Alex
