530 question
Kozmo
03-24-2008 08:34:50
I need some help on a 530 Case.The lift goes to the top and will not go down.Even if you let it set for a long time.Any ideas?Thanks Kozmo
J Heitkemper
03-27-2008 06:30:43
 Re: 530 question in reply to Kozmo, 03-24-2008 08:34:50
My 430 acts like that ,after we put in new seals in the hydro lift, It only does it if the arms are left all the way up in cold weather , I have hooked the arms to a short chain low on a post and gently bounced the clutch while having the hydro lever in lower position ,, Works every time , Jim
dwsc
03-25-2008 20:51:56
Does this tractor have standard hydraulics or is it a drafto matic setup?
BarryfromIA
03-25-2008 18:36:56
Check the oil level in the front transmission. If no oil is getting to the pump nothing is going to happen because of the interlock valve on side of the hydraulic valve. It needs pressure to allow oil to pass through.
Kozmo
03-25-2008 05:57:55
The lift arms will not go down in any position.No matter where I put the lever it will not go down.Thanks for the response.Kozmo
JGarner
03-27-2008 05:54:30
 Re: 530 question in reply to Kozmo, 03-25-2008 05:57:55
Kozmo, I think Barry may have the answer. I was looking in my Case 350, 500b, 600b service manual last night (Case didn't complete the manual set for the 630 and refers to this one) and I believe hydraulic fluid level or flow may be the problem. I have the manual scanned and saved as pdf files. If you will turn your email on or email me, mine is one, and send me your address I will send you the hydraulics section which includes the eagle hitch information. I found nothing specific about the arms not going down, but enough related information on fluid flow and drawings that I believe it will help you diagnose and solve your problem.
Jim
JGarner
03-25-2008 15:41:49
This helps. I can go into my service manual and owners manual for my 630 (virtually the same tractor except horsepower) and see what I can find. Keep monitoring this post and I will respond with what I find, but it sounds like a stuck hydraulic spool or valve. May take some disassembly and cleaning.
Jim
JGarner
03-24-2008 12:29:50
You probably already know this but have to ask to find a starting point, I do not mean to offend. Are you pushing the control lever backward from the neutral point location to drop the arms? Just letting the lever return to the neutral point will not lower the arms its not like Ford/Ferguson systems.
Ford has up and down positions and the Case lever should return to neutral when the appropriate height is reached. The lever must be pushed backward to allow pressure in the system to bleed back to the reservoir and the quadrant control should return it to neutral on downward motion.
