Case DO Hand clutch
JVS
03-23-2008 11:43:42
I just bought a Case DO tractor. That has been in storage senice 1960. It has a hand clutch. When I push it forward, i cant get it to pop in. I pushed as hard as I could and still could not get it in gear. The shifter moves fine. Does anyone have any idea what might be wrong? Thanks for any help in advance.
Mathias NY
03-23-2008 19:15:10
 Re: Case DO Hand clutch in reply to JVS, 03-23-2008 11:43:42
Do you have the tractor running yet? The clutch will act differently when the tractor is running. It probably has some decomposed oil on the clutch plate. Time spent running with clean oil might clean it up.
Newton Miller
03-23-2008 14:28:05
sounds to me like you are going at it backwards. you pull the handle back towards you to stop and for shifting push it fowards to go. being that the tractor has set that long the disk may be swelled up a bit and you will have to take the cover off and back off the adjustment on the pressure plate a bit.
