Case Paint
patsdeere
03-23-2008 10:20:20
I just got the cost from Napa for paint and about hit the floor. I was quoted $236 a gallon since I could only get the 54 series of paint since I am in California. $&$*%$# environmentalist. I guess the 53 series is still available outside of CA for $125 a gallon. I guess I am off to Case or PPG for paint since there is no way in this world I am paying that much for paint. It would almost be cheaper to drive across the stateline and get some of the "bad" stuff.
JGarner
03-24-2008 07:02:13
 Re: Case Paint in reply to patsdeere, 03-23-2008 10:20:20
The high price will be there for any modern 2 part enamel paint no matter what brand, PPG, DuPont, Martin Seynor, Ditzler, etc. I found this out several years ago when buying DuPont Imron for trade show models I was having painted. Du Pont has a non carcenogenic Imron (but its still $125+ per gallon in Houston, Texas) now that everybody is switching to but there are newer automotive paint systems out there now that hold up better than old one part "implement enamel" and even Imron which I though was quite durable. Just depends on what you want.
Also, gents and ladies, please be careful when painting these newer two part automotive paints. They are toxic to breath and the instructions indicated that a charcoal respirator type mask should be worn when painting even in highly ventilated areas (like outside).
El Toro
03-24-2008 11:31:12
 Re: Case Paint in reply to JGarner, 03-24-2008 07:02:13
You should use a supplied air system when spraying that paint. Hal
El Toro
03-23-2008 18:29:55
The PPG Omni is about $ 30.00 a quart when I bought it in 2006. It was the Farmall red and the red usually cost more. Here's a PPG paint web site for farm tractors. I think Dupont is on it too. The Duponts are not far from me in Delaware. Hal
www.worldpath.net/~thompson/
Walt davies
03-23-2008 12:03:25
If they keep it up we won't be able to paint anything I bet that will go over big in the body shops.
Walt
