Refilling 400 Hyd. housing
ihr190
03-23-2008 04:50:52
The book says ATF Type A. Problem is none of the rest of my tractors use this. Does it have to be ATF? Or can I use hydraulic oil that is in everything else I own.? Thanks. Rob
mEl
03-23-2008 05:32:08
 Re: Refilling 400 Hyd. housing in reply to ihr190, 03-23-2008 04:50:52
All depends what Hyd oil you are useing in every thing else you own, If your oil is Hytran Ultra it will be fine, there are others but do not use just any hydraulic oil unless it meets Case's specs. mEl
