S sleeves info needed
Jim McVay
03-22-2008 19:48:46
What is the legnth and O.D. of the 3.625 I.D. sleeves? Do the sealing o-rings go on the sleeve or in the block?
L.Lamp
03-22-2008 20:54:14
 Re: S sleeves info needed in reply to Jim McVay, 03-22-2008 19:48:46
I do not know the length or diameter, but on pre'52 engines there was only one seal and it was in the block. On the later tractors there were two seals. I believe they are in the block also. The sleeves are interchangeable from '41 thru '51. The '52 thru '54 had a different sleeve common to only those years.
mEl
03-23-2008 03:24:59
 Re: S sleeves info needed in reply to L.Lamp, 03-22-2008 20:54:14
LL, thanks for the info, I have done many DC's but not many SC's over the years!! Jim, The sleeves will have to be turned down to fit the VAC block and then you can put the Oring grooves anywhere you want them. A bigger sleeve yet could be fitted (i've seen them) with a bit of block boring but 4 inch is pushing the limit for reliability. mEl
