Case 930 6 speed Governor
Travis M
03-22-2008 18:10:14
I need a complete timing cover with governor parts for a case 930 6 speed. I also need a cam and cam gear for the lp 930 6 speed
TravisM
03-22-2008 18:25:03
 Re: Case 930 6 speed Governor in reply to Travis M, 03-22-2008 18:10:14
I think a cam and gear out of a 930 8 speed gas would work also along with the timing cover and governor pieces
DKase
03-22-2008 18:46:54
 Re: Case 930 6 speed Governor in reply to TravisM, 03-22-2008 18:25:03
Better check the part numbers really close. I do know on the diesels the PTO speed is at least 300 engine RPM's different, and the cams are entirely different. The 6 speeds will lug down to 1000 RPM's and run all day. The 8 speeds will lug down to 1600 and die.
Travis M
03-22-2008 19:03:30
 Re: Case 930 6 speed Governor in reply to DKase, 03-22-2008 18:46:54
I'm going to have the cam ground for a pulling tractor. The diesel cam may even work, but I know the gear is different.
