Case 530 Engine?
Dsundy
03-21-2008 07:48:48
I recently bought what I believe is a 530 Utility with a model 31 loader. My question is what type of engine does this have in it? I think its a 159 gas but the oil filter is in the wrong place and the S/N tag is on the left side of the block below the carb. The S/N from what I can see is 2000741. Any ideas on what type or year from that number?
Thanks
Dennis/Ohio
04-06-2008 17:39:33
 Re: Case 530 Engine? in reply to Dsundy, 03-21-2008 07:48:48
third party image
My 530 is a 1961. I"m assuming You saw the pictures I posted? Mine should have the vertical filter adapter like yours but mine has a later model engine. The model & serial number for these is usually missing because the tag is riveted to a bolt on trim panel. Nice huh? I think I can send a picture of a 530 with tag location. Tag is on panel on right side of fuel tank. Also I made my own dash panel, your"s should have a gauge cluster.
Best wishes, Dennis..... ..
dsundy
04-14-2008 09:49:26
 Re: Case 530 Engine? in reply to Dennis/Ohio, 04-06-2008 17:39:33
third party image
Thanks Dennis, great pictures. I think the S/N tag has long since gone bye bye. There are holes where I think the tag once was, oh well. Great tractor though, does everything I ask of it. The one thing I wish it had was a diff lock. Do you by chance know if that option was ever available on the 530"s?
Dan, WA
Dennis/Ohio
04-15-2008 00:27:32
 Re: Case 530 Engine? in reply to dsundy, 04-14-2008 09:49:26
Did a URL picture link. The other photos are too small. http://photosmart.hpphoto.com/LargeView.aspx?SKU=walmart&IDKey=0&JobID=6d53146d-881a-4c0f-b4ca-3e353b75efc4&back=FilmstripView&index=0#
dsundy
04-15-2008 08:49:22
 Re: Case 530 Engine? in reply to Dennis/Ohio, 04-15-2008 00:27:32
Much better pictures. I went and looked again for the tag and its definitely gone. Just holes were someone drilled out the rivets. Near as I can tell this one is somewhere between 8191147 and 8262800.
Dan, WA
Dennis/Ohio
04-20-2008 05:23:39
 Re: Case 530 Engine? in reply to dsundy, 04-15-2008 08:49:22
Dan,
What I keep trying to tell you is the tag was never mounted in the holes you found. The tag was riveted to the panel bolted on the side of fuel tank. Someday you"ll see a 530 with the model tag and it will all make sense. I had to see one to believe it. Mine has the holes on the right side of the instrument panel just like yours. I don"t know why the factory put those holes there. Possibly the dash was used on some other model that did mount the tag there?
Dennis/Ohio
04-14-2008 11:14:50
third party image
third party image
My panel is also missing part # 16 on right side is where they put the model & serial number tag. when the panel is removed for repairs the model & serial number is lost.
Dennis/Ohio
03-28-2008 23:50:53
Where is oil filter? Later model 159 had oil filter horizontal on front of engine below generator.
Link Picture #7
dsundy
04-06-2008 08:10:49
 Re: Case 530 Engine? in reply to Dennis/Ohio, 03-28-2008 23:50:53
This one has the oil filter vertical between the distributor and the generator.
Thanks
Tom (Ks)
03-21-2008 19:53:44
Carb should be on the left and the filter on the right. That low of serial number should be very early 60's.
