hydraulics
Kevin in Iowa
03-20-2008 19:46:16
I am in the process of putting a log splitter on my 830 caseCK. I am not all the familar with the hydraulics on this case. I would like to use the valve on the splitter, and looking at the tractor I see the pump has 4 hose coming out of it for the bucket, raise and lower and tilt, I am guessing. If I unplug a pair of these and plug my splitter into those two lines,will I have to somehow hold the lever open for those lines to have hydraulics pressure to them? Any advise would be greatly helpfull.
thanks again.
DKase
03-21-2008 06:45:46
 Re: hydraulics in reply to Kevin in Iowa, 03-20-2008 19:46:16
I have a loader valve mounted on my splitter, and hook the hoses to either the top, or bottom pair on the tractor. Wire the tractor valve so the pressure will not kick it off, and use the valve on the splitter to control. Make sure you have an open center valve. I have seen splitters that hook up a long rod to their tractor valve that reaches the splitter, and use the tractor valve as the control valve. That works fine also, but you have to rig something didderent for each tractor that is used.
