Case 611-B
Genos
03-19-2008 19:17:09
Have A Friend Has A Bad Engine in a 611-B And Wants to find another engine if he can. What Else Had That Engine? Is There A Combine Engine That Is The Same? Or What Else Would Bolt Up? Thanks
Genos
03-20-2008 20:24:41
 Re: Case 611-B in reply to Genos, 03-19-2008 19:17:09
The 611-B Has A 164 Engine, What else has that engine? Or Would bolt up?
bradley martin
03-20-2008 12:08:10
The 530 gas is also a 159 engine. The C.O.M. versions ran about 100 rpm faster than the dry clutch versions. If you check the archives, you will find some discussions about using an engine from the 660 combine..if I recall the combine engine(which is more cubic inches) is 2 or 3 inches longer which require some modifications to the tin work and steering.
JGarner
03-20-2008 10:51:49
511B is the dry clutch version of the tractor. I think that is a 159 cid engine. The 611B has a Case-o-Matic drive. I think there are combines with a similar engine also but I am mot a combine person, maybe someone else can help on that.
