Hydr/trans Filter
Tony Nelson
03-19-2008 16:26:12
Hi,Im going to be servising the tractor and was wondering where the hydr/trans filter are located on a Case 611B?Thanks Tony
c. hess
03-20-2008 11:29:13
 Re: Hydr/trans Filter in reply to Tony Nelson, 03-19-2008 16:26:12
If case o matic there are 2 fillters-1 is up front in side grill area -it will have a cap on top with 4 cap screws on top. This is for oil in Case o matic. Other filter is on right side of torque tube under fuel tank an also has 4 cap screws holding cap on. Both filters are edge wound paper. Donot damage as they can be cleaned if careful however new is better. Also under torque converter housing you should remove plugs an with someone turning engine you will see a allen head plu g on converter that should be removed an converter drained. sHOULD ALSO ADD THAT YOU NEED TO BE ABSOLUTELY SURE NO DIRT IS LEFT IN FILTER HOUSING ESPECALLY ON front filter. System uses a common sump for both hyd an c o matic.Holds 16 qt of type a auto or equivelent.
