930 case serial #
Bollpuller
03-18-2008 18:59:16
Recently purchased a 930 case (late model with 3point and the serial no plate is missing. The tractor is lp and I need to know if there is a stamped serial# somewhere. Does this tractor have more than 1 place for hydraulic oil?
Bollpuller
03-19-2008 18:42:07
 Re: 930 case serial # in reply to Bollpuller, 03-18-2008 18:59:16
Thanks!!!!! !!!!
bradley martin
03-19-2008 01:30:11
Can't help you w/ serial number, but other than rearend the only other place where hydraulic oil is called for is the power steering pump located at the front of the engine. The late models used the rear end as the resevoir for the hydraulic system...a big improvement over the chain drive, earlier models.
