Tune Up
Gary Covert
03-18-2008 16:30:22
I understand from tune up materail I got from the forum that the timing mark is on the flywheel. Where is the access to this located?
c. hess
03-18-2008 17:16:22
 Re: Tune Up in reply to Gary Covert, 03-18-2008 16:30:22
If YOU AR TALKING SC-DC. It is found by looking in small hole with pipe plug in it on rt side of clutch housing . Remove pipe plug an with some one turning engine slooooly an with flash light you will see it punched on flywheel, You should wipe off oil with rag first .It will show tdc when directly at hole.
