Early 830?
HossinMe
03-18-2008 16:29:03
Ive got an 830 com 1960 model.Ive got owner and shop manuels.All books Ive got show a spin on oil filter for rearend under back of left floorboard yet mine has none.Wassup?ser no. is 8160583 Thanx Hoss
HossinMe
03-18-2008 18:18:58
 Re: Early 830? in reply to HossinMe, 03-18-2008 16:29:03
Gotcha,I thought that was it. Thanx Hoss
c. hess
03-18-2008 16:47:06
Your oil filter is below pto shaftat rear of tractor. It is inside tractor. Drain oil than remove 3 bolts on cap in front of drawbar support.there an you will find a edge wound paper filter in there. Be careful an dont damage it. Replace with new if avaible otherwise you may have to wash an reuse. There is about 4 gallon of case tch oil in there if a early 830-if one of later it will hold 18gal.930with draft o matic had spin on filter under left floor board. 830 with draft o matic probably did also.
