680B Cylinder Sleeves
KevinT
03-18-2008 08:30:52
I have a 68 680B Backhoe with an A267D engine. It only starts with ether and I am getting ready to sell it and want to do a minimal rebuild to make it better. I am also getting exhasut in the radiator so i know it has a bad head gasket or cracked sleeve. Are these sleeves wet or dry and can I do just the sleeves rings and a little valve work or is it better to just do a full in-frame rebuild and increase selling price. My understanding is wet sleeves can be pulled with a puller and dry sleeves need to be dored. Is that correct.
c. hess
03-18-2008 16:16:52
 Re: 680B Cylinder Sleeves in reply to KevinT, 03-18-2008 08:30:52
Your engine has wet sleeves that can be pulled pretty easy with puller.Would recomend you pull them an replace o rings at bottom even if you use old sleves. However you need to look very closely at head when you remove an try to determine where compression leak into radiator is coming from. Gasket- head crack or sleeve area especally around top an counter bore. If you dont see culprit would recomend you take head to repudable repair shop to check for cracks.They will have to pull injectors an valves. an Keep in mind if you grind valves you will lower compression an make starting worse. As you can see this will cost a few bucks .Dont know value of your hoe but you will need to decide amount you want to spend.
