Racine, I think we have a problem.....
Alan Golden
03-17-2008 20:47:19
third party image
third party image
I think I have a bit of a problem with the hand brake band on my 49 LA.
combinekid
03-17-2008 21:25:00
 Re: Racine, I think we have a problem..... in reply to Alan Golden, 03-17-2008 20:47:19
Hay Alan I can also see in your pic the belt pully brake. Did you have mutch trouble gettin that off? I tried to take mine off 4 years ago whe I started my resto but I could not get the pin out. I think I am goin to try again though cause after running my tractor a bit I think I need new seals for that clutch shaft. Maybe I'll have to try some heat this time. As for the boat anchor idea. Not bad Not bad cept I'd want a big fat heavy old anchor and I have yet to find a ship on the farm so not sure were I'd find one haha LOL!
Alan Golden
03-17-2008 21:34:01
 Re: Racine, I think we have a problem..... in reply to combinekid, 03-17-2008 21:25:00
The pulley brake took a tad bit more work and a few more tools. Wrenches for set screws, torch, drill, punch, sledge hammer, a few band-aids, and some Adult Liquid Solvent.
Actually, the head of the pin had been mushroomed out, so I had to drill out the pin, put some heat to it, then take a punch and drive the slivers out. There was just BARELY enough clearance to get the brake arm out, once I took a gear puller and tugged the pulley out until it was hitting the tire.
combinekid
03-17-2008 21:50:33
 Re: Racine, I think we have a problem..... in reply to Alan Golden, 03-17-2008 21:34:01
yep sounds bout like what I thought I might have to do. Then I guess I have to make a new pin because I bet mine is in there every bit as hard as your's was. Oh well the joys of workin on the old stuff right? On Saterday I had to get our John Deere 4630 hooked up to our 16' foot tandum disk because we worked ground and planted peas today. After getting the disk ready I had the crazy Idea to see if the LA would pull it. What do ya know it did! but it was quite a load for it. I was goin slighty down hill and of corse I dont have no hydrolics so I had no way to raise it. I made a big wide turn at the bottom of the hill and then tried to come back up it was at this point that I spun out. Had to drop the disk and go retreve it with the Deere. We have very sandy soil here in Eastern WA so traction is our biggest problum. A 16' disk is a huge disk for a LA size tractor here. Sure was fun to here that big engine with no muffler or pipe Lug down and pull! Now I need to find me like a 12' disk then I could really have some fun. Thats the first time that this tractor has worked in somewere around 30 years and i think it kinda enjoyed it self, I know I did!
Alan Golden
03-17-2008 21:55:30
 Re: Racine, I think we have a problem..... in reply to combinekid, 03-17-2008 21:50:33
I've got a 4 bottom Case Centennial plow spotted and spoke for. Just have to go pick it up. However, I've got to get tires before I can try to do any work with mine. I think there are only about half a dozen lugs left on the rubber, and the rest is just cord. I'm waiting to see if I can win the lottery before I can afford to buy some new tires.
What is your email and I'll send you some pics.
combinekid
03-17-2008 21:59:34
 Re: Racine, I think we have a problem..... in reply to Alan Golden, 03-17-2008 21:55:30
e-mail is open send away I'll be lookin for em
combinekid
03-17-2008 21:05:27
uhhhhh I do! Our farm is pretty hilly I made sure that I had that brake band in good workin order cause I have not fixed my hyd brakes yet and I wanted to make sure I did not take out the barn or somethin when I took my LA on its first test drive!
Alan Golden
03-17-2008 21:09:13
 Re: Racine, I think we have a problem..... in reply to combinekid, 03-17-2008 21:05:27
Tie an anchor on the drawbar and kick it off the back of the tractor if you find you are about to run into something. LOL j/k
combinekid
03-17-2008 20:57:35
Alan I cant see all of the band in the pic but it looks like your lineing is just worn out. I just had the band for my LA relined at the local auto machine shop. With tax the bill came to $43.00 hope this helps
Alan Golden
03-17-2008 20:59:20
 Re: Racine, I think we have a problem..... in reply to combinekid, 03-17-2008 20:57:35
Oh....who needs brakes anyway?!?
