3-point hitch for a 1948 Case Model VAC
Gale Roberts
03-17-2008 19:27:34
Is there such a thing as a conversion Kit for making a 3-point hitch for a old Case Model VAC Tractor? I would like one for attaching a bush-hog to the rear of my VAC..... ..Gale
mj
03-19-2008 08:32:31
 Re: 3-point hitch for a 1948 Case Model VAC in reply to philcaseinWPA, 03-17-2008 19:27:34
old said: (quoted from post at 20:40:04 03/17/08) I don't know if they make a kit or not but I know one of the VACs I have has a sort of up side down 3 point on it. This one lifts by way of the center lick hook up instead of by lifting the 2 lower arms. I know I could make a 3 point for one pretty easy the way the hyds. are on the 2 I have
Hobby farm
Here's one on my '48 ..... more on the link :)
third party image
Link
'C.Amick' was referring to this:
third party image
The problem with that set-up, though, is that you have to step over the links every time you get on or off :cry:
That info is at:
Link
C. Amick
03-18-2008 08:56:21
 Re: 3-point hitch for a 1948 Case Model VAC in reply to Gale Roberts, 03-17-2008 19:27:34
There is a conversion kit that Case used to sell. I believe there is a manual showing it on the web site listed below.
JGarner
03-18-2008 04:47:21
Don't know where you are but take a look at ebay listing Item number: 160217725459 . This VAC has 3 pt, I am guessing eagle hitch. Just swith out rear ends with yours. 49 was the first year for eagle hitch you may get a good fit. Its 7:00 CDT right now and the listing only has 8 hours 20 minutes to go. If you are close and could pick up a parts tractor for $450 or so it might be worth bidding.
Fred Goodrich
03-18-2008 04:25:00
Do you not have eagle hitch? I have a VA with a Monroe 3pt conversion but how about an eagle hitch? It will take your Cat 1 implements. I have whatever you need. Thanx Fred. 6076423293
old
03-17-2008 19:40:04
