swing cylinder leaking
R FARRIS
03-17-2008 12:31:51
I have a swing cylinder that is leaking and was wondering if I could take it out to repair with out taking off the hoe.
R FARRIS
03-18-2008 13:26:58
 Re: swing cylinder leaking in reply to R FARRIS, 03-17-2008 12:31:51
Thanks Kevin
I forgot to say this was on a case 580c. thanks for the info bob
KevinT
03-17-2008 14:04:57
I am guessing that it is leaking around the gland. If you swing the boom L/R so the leaking cyclinder is fully extended you can disconnect it from the doom and remove the gland and rod from the cylinder housing. Depending on what shape the packing is in this can sometimes be difficult but I have done both mine this way. Once out of the cylinder I usually reattach the rod to the backhoe so it is secure and I can get some force on the packing nut. I have yet to get one off without the use a 6" piece of pipe. Depending on where you are getting the parts from, most dealers will break the packing nut free for a couple of bucks if that is easier.
