MS TSX 635 issues
Dave Beiter
03-17-2008 08:43:03
I have a Case 211B with a MS TSX 635 carb that I cannot get to stop dripping. We have used a steel needle valve and seat and a neoprene seat and valve to no avail..... I have had this thing off 4 times now and am getting quite good at it.... Any ideas??
Thanks
old
03-17-2008 09:44:43
 Re: MS TSX 635 issues in reply to Dave Beiter, 03-17-2008 08:43:03
The seat may not be in as tight as it needs to be, or the float is set wrong or has a small hole in it and gets heavy. Now as far as the rubber tipped needle you have to set them for them to work well. To set it you take the needle and drop it in the seat and then take something and tap on it a few times, not real hard just a few gentle taps.
