SC Clutch Adj
jjamna
03-16-2008 19:48:42
I adjusted the clutch on my 48 SC now I can't get the locking pin to come out. Any suggestions?
jjamna
03-17-2008 16:08:43
 Re: SC Clutch Adj in reply to jjamna, 03-16-2008 19:48:42
Thanks Guy,s I got that rascal. Sprayed PB Blaster ( Good Stuff) and kept pushing on it with a screw driver and it finally popped out.
C. Amick
03-17-2008 09:04:58
It could just be a little rusty. I try to spray mine with P.B. Blaster or some other type of penetrating oil before I push the pin in. Soak it good with penetrating oil for about a day and then tap it a little to see if you can get it to pop back out. Can you get to it with a pair of needle nosed pliers to try to move it a little?
old
03-16-2008 20:46:47
Well can't say I know a lot about them but its probably one of 2 problems. #1 you don't have the hole lined up right. Or #2 the spring on the lock pin has broke which is not good
