800 case dozer hd277 continental
Ernie G.
03-16-2008 17:21:18
any answers as to why it would be losing compression past one of the injectors. i took the injector out and put it back and still cannot correct the problem
george md
03-16-2008 18:41:17
 Re: 800 case dozer hd277 continental in reply to Ernie G., 03-16-2008 17:21:18
Ernie,
There is a copper sealing washer in the injector hole , it is either damaged or missing.
george
Ernie G.
03-18-2008 17:38:50
 Re: 800 case dozer hd277 continental in reply to george md, 03-16-2008 18:41:17
hi george! got the compression leak fixed around the injector, the engine still has a slight miss however. had a guy stop buy today and take a look at the old girl and check the charging system and a few other things. the generator is working fine. seems to think that i should do a compression test, any recomondations on what type of compression gauge i could use. also had to add antifreeze to the system a few times. there is not any in the oil. what could i do if the cylinderr head is cracked and water is going out the exhaust side.
thanks! ernie from montrose
george md
03-22-2008 20:54:02
 Re: 800 case dozer hd277 continental in reply to Ernie G., 03-18-2008 17:38:50
Ernie,
I got busy and missed reading the board for a few days and almost missed your post. Send me an email , I'm more likely to see it. I'll look , I think I have a compression tester for that type injector port.
If the antifreeze is going in the exhaust, you should smell it. More likely going out the overflow tube especially if you are getting any pressure in the radiator from compression.
george
