Cessna 24504 gear pump off Case back hoe
geworthomd
03-16-2008 16:07:32
Does anyone know much about this pump? Can it be run open center?
How could I port off of it so that my power steering can always see flow even with the hydraulic cylinders in operation?
jdemaris
03-17-2008 10:13:41
 Re: Cessna 24504 gear pump off Case back hoe in reply to geworthomd, 03-16-2008 16:07:32
That's a very common gear pump used by Deere, Case, Ford, etc.
If you DON'T have it hooked to an open-center control-valve, the pump will makes it's own "open center" by blowing to pieces.
Bob
03-16-2008 17:20:03
It almost certainly is a simple gear pump, designed for use with an "open center" system.
How many ports does it have, just one "in" and one "out", or is it a double pump or pump with a built in flow divider, with two outlets?
In general, you use a "flow divider" with adequate capacity to handle the full flow of the pump, to tap off a constant flow of a few GPM's for power steering. It needs to have a relief valve built into the "constant flow" circuit.
