Case 630 Diesel
Lee Brown
03-16-2008 12:29:37
Hello! What's the size of the engine (c.i.) in a Case 630 diesel? How about the size of the one in a 430 diesel?
Also, does the wide front end from a 400B fit a 630?
Thanks for your time!
Lee
Lee Brown
03-17-2008 07:16:18
 Re: Case 630 Diesel in reply to Lee Brown, 03-16-2008 12:29:37
Thank you all! This is the first and only place I go to hear from the experts, and I appreciate your time and responses!
Lee
triplerange
03-16-2008 12:39:58
188 cu in....same engine just more fuel. I would think if both are wide front tractors the fronts be nearly identical.
Roger (Mi)
03-17-2008 05:35:43
 Turned up infection pump. in reply to triplerange, 03-16-2008 12:39:58
While the 430, 530, 630 diesels are all 188 CID, the fuel injection pumps and timing are changed for each model. 430 = 35 factory horsepower (most put out 40)
530 = 43 factory horsepower
630 = 52 factory horsepower
JICase
03-17-2008 06:41:22
 Re: Turned up infection pump. in reply to Roger (Mi), 03-17-2008 05:35:43
The 630 will run more rpms also.
Don't know about the 530.
