case stuff??
Kirk in ks,
03-16-2008 06:40:41
On my Case 2670,,
Is there only one filler neck for the hydralics and no more ?
I was thinking there was another place to put hyd fluid?
but I guess the one in front of the cab on left side is the main filler tube,?
I guess the tank below holds all the fluid for the complete system,
How do you clean the small site windows on that tank?
do you have to drain the tank and then somehow punch the little windows out so they can be cleaned out and then you can see how much fluid is in there?
I like the 2670 alot but I dont have PTO on it,
I found out where the seal on that pesky lift cylinder was leaking from?
Its on top,
& then its dribbling down the side of cylinder and taking the paint off with it,
I dont have to drain the systen to fix it do I???
I was hoping to just undo the hose from the top and just lift the cylinder out , and get it redone with a new seal,
