David Brown 995 tractor Hydralic problem?
Nick Dines
03-16-2008 00:53:55
Hi,
I changed the gearbox oil on my white David Brown 995 tractor and the filter, as the oil was like sludge at the bottom! With freash oil, there is now no hydralic pressure, it lifts up the arms, but as soon as you try to put anything on the back, it just wont lift them, the oil is there but just no real pressure? Any ideas of another filter hiding anywhere or possible cause of blockage?
Any help or advice would be very greatly recieved!
Cheers
Nick
richardinnz
03-16-2008 02:42:58
 Re: David Brown 995 tractor Hydralic problem? in reply to Nick Dines, 03-16-2008 00:53:55
Some dirt has probably been dislodged when you changed the paper filter and cleaned the magnetic filter and found its way to the hold and bypass valves in the selectamatic control valve located near the lift control lever. They need to be removed, cleaned and flushed. As far as I can remember this is in the operator instruction book for details of how to do it. It is a common problem, if the hydraulics worked before you done the oil and filters, it is the first place to look.
