need case 400 info......asap please.
steve-ny
03-15-2008 18:50:07
going to look at a 400 sunday morning. gas, wide front,recent paint(6-7 years ago) needs manifold, he said head gasket blew while he was running it( white smoke/steam out ex.) I know it may be much worse than just head gaskets. he wants $750 for it, I offered to swap him a farmall super C for it. he is thinking about it. is there anything good,bad,ugly about this tractor? should I run away? any info, or experience would be helpful. thanks. steve
ed in cny
03-17-2008 06:25:35
 Re: need case 400 info......asap please. in reply to steve-ny, 03-15-2008 18:50:07
Super C? What wrong with it? I may be interested in one. If you are still interested in making a trade lets talk. Does the super have the two point?
steve-ny
03-16-2008 17:13:30
thanks for all the help. I looked at it today, doesn't look too bad, needs work, ( dont they all???) I decided I really didn't need another one, so I listed here in the photo ads for him. thanks again, steve
steve-ny
03-16-2008 02:59:19
what do you mean "big 400"? it is about the same size as a farmall M, not a utility style.
TimBinWV
03-16-2008 04:24:02
 Re: need case 400 info......asap please. in reply to steve-ny, 03-16-2008 02:59:19
Steve,Case made 2 different 400 tractors. One is a round-nosed tractor which is rather large,and the other is a square-nosed tractor,which is rather small. The "Big" 400 has a round medallion in the center of the grill,also. It's been hailed (on this board) as one of the best tractors Case ever built a lot of times. I missed a tricycle front that needed an overhaul closeby for $1,000. Wish I had found the money!
steve-ny
03-16-2008 06:03:19
 Re: need case 400 info......asap please. in reply to TimBinWV, 03-16-2008 04:24:02
I searched the tractor photos on this site, and I guess it is a "big" 400.has rounded grill with no headlights in grill. about how many horse is this 400? what is caseomatic? is it like the SOS that ford had years ago? if it has it should I avoid it? thanks, steve
Doc Larry
03-16-2008 16:22:48
 Re: need case 400 info......asap please. in reply to steve-ny, 03-16-2008 06:03:19
Steve,
The 400 round nose never came with COM. If you"ve already looked at it you know it"s a 4 speed with high-low. Great tractors. HP is about 52, and it will pull like it has more.
Larry
TimBinWV
03-16-2008 09:25:24
I don't believe the 400 you have was ever equipped with the COM.
John Noname
03-16-2008 08:53:36
Steve, Caseomatic came on the 800, 600, and 400 which followed the 400 you are looking at. It was a good transmission if you take the time to learn how to use it. As was stated in one of the posts the 400 was one of the best tractors Case ever made plus the 300-350.
Art Lowder
03-15-2008 21:47:03
I have located 2 Case 400s, been stored inside since the farmer quit using them many years ago 1 is a DSL, 1 is a GAS, which is the better deal for power any info.would be helpfull ,and what is a fair price for either one thankyou for your time.
John Noname
03-16-2008 08:57:58
 Re: need case 400 info......asap please. in reply to Art Lowder, 03-15-2008 21:47:03
It depends on your use. If you are working it hard the diesel stands up better. If this isn't going to be worked hard or not steady the big consideration is the cost of gas versus diesel today. In our area the difference is considerable. The best bet is to buy both then you are covered and happy!
Art Lowder
03-16-2008 19:53:28
 Re: need case 400 info......please in reply to John Noname, 03-16-2008 08:57:58
thanks for the insight,I was going to put a 6ft. 3 point mower on it or grind feed with it right now we use JD 720 gas for every thing.
Case400
03-15-2008 19:25:58
Is it a big 400? They were built from 1955-57.
They have live power and PTO.
8 speeds forward 2 reverse. 55HP 251 engine. If your are not familiar with the shift pattern it can be kind of tricky. I think the brakes are the only down fall to the tractor. Once the brake rod dust boots are cracked or riped water can get into pads. Most of the time it is an easy fix. Pads are still available. It is not uncommon for the PTO on the tractor to creep when it is not engaged. Super 400"s had better PTO brakes. Power steering and three point hitch add to the value of the tractor. The last three I saw sell at auctions sold between $1,800 and $2,800 In my opinion it is one of the best tractors Case built. Between me and my uncles we have about a dozen. Hope this helps, Dan
Larry59
03-15-2008 19:08:05
parts are a little harder to get. But is this a casematic transmission? If so you can have torque troubles in transmission. But since it don't run it is hard to say.
I have the 311 case gas 4 cylinder 146 makes it a 30 hp motor. But is the triple range tranny. Like it real well. There is a daul range tranny also. Others may have more to say.
