Mineral oil Brake fluid
RD TX
03-15-2008 08:54:56
I went to Tractor Supply and asked for a mineral oil brake/clutch fluid and they had no idea what I was talking about. They did produce a mineral oil based hydraulic fluid but it appeared to be just a different kind of transmission fluid in a 2 gallon container. Can someone give me a brand name of what I can use for mineral oil brake fluid?
Thanks,
RD
richardinnz
03-16-2008 02:52:29
 Re: Mineral oil Brake fluid in reply to RD TX, 03-15-2008 08:54:56
DO NOT USE DOT BRAKE FLUID, IT IS NOT MINERAL OIL You need LHM, it is green in coulor, failing this use a very light hydraulic fluid. LHM fluid is used in Citroen cars for the hydraulic suspension, David Brown tractors, Claas and Renault Ares range of tractors. Use of a DOT fluid will destroy the rubber components in the brake system causing leaks and brake failure. Systems using LHM usually have green tags on the cylinders and somtimes green filler caps.
Ken L
03-15-2008 13:03:41
Your New Holland dealer has it. I don't remember the part number but they use it for brake and clutch oil.
RD TX
03-15-2008 09:54:24
I have a CASE 1594. The manual says use a Mineral oil for the brake and clutch fluid,
Thank you for your help.
RD
Duner Wi
03-15-2008 12:00:34
 Re: Mineral oil Brake fluid in reply to RD TX, 03-15-2008 09:54:24
I doubt if you want DOT 3 brake fluid. Probably need something like Farmoyl TO-4. They have website. farmoyldotcom.
Sorry I can't help.
Duner Wi
03-15-2008 09:37:09
DOT 3,4 and 5.1 brake fluid is mineral oil based with additives. DOT 5 is silicon . You don"t want that
Other wise ixquick search said this. "Hydraulic system mineral oil brake fluid [HSMO] is a blend of mineral oil and additives. It is the most rare, the most expensive, and is not compatible with any other fluids." So I don"t really have an answer.
Might help if you said what fluid is to be used in.
