case 580 c fuel in oil
jbrentn
03-13-2008 19:11:08
anyone know why there would be fuel in my oil on my 580c ? it has a case 207 engine in it. any help would be great!
jdemaris
03-14-2008 13:12:49
 Re: case 580 c fuel in oil in reply to jbrentn, 03-13-2008 19:11:08
As Old mentioned, fuel pump or the injection pump. The seals in the Stanadyne injection pump are a common leak area. You remove the pump from the engine while the pump driveshaft stays where it is - on the engine. You then replace the two umbrellas seals, and carefully reinstall the pump over them. You also have to look into the pump end and make sure the bushing doesn't have grooves worn into it from the seals. New pump bushing costs $10.
mEl
03-14-2008 03:53:38
Is it running smooth , if there is a dead cylinder due to pushrods being out of place it will put fuel down by the rings, I personally have found this many times with the 188s when working with the 530-580s in out sales area. Otherwise , the umbrella type seals on the injection pump driveshaft are probably deteriorated and possibly the pump bronze bushing may have a groove worn in it where the seal rides. mEl
old
03-13-2008 19:31:33
If it has a feul pump it could be going bad. And or seals in the injector pump could be bad. Either one or both will cause that
