Do NOT use brake fluid!
Roger (Mi)
03-13-2008 00:37:05
TCH (Torque Convertor Hydraulics) is basically the same as all trans-hydraulic fluids. AutoZone in your area? They carry the equivalent fluid in 5 gallon buckets. It says right in the fine print that it's compatible. A trans-hydraulic fluid has a few more lubricating properties than regular hydraulic fluid.
Roger (Mi)
03-16-2008 00:40:56
 Trans-hydraulic fluid usage in reply to Roger (Mi), 03-13-2008 00:37:05
Trans-hydraulic fluid is meant for transmission/hydraulic usage. There is NO need to use that in a backhoe hydraulic system. Use a straight grade hydraulic fluid. There are no moving parts that need the extra lubrication (transmission gears) of a trans-hydraulic fluid.
