case 300 question
Kenneth Hevner
03-12-2008 18:49:28
I have a 1957 Case 300 with a 6 volt system. As anyone who has ever used one of these tractors knows, the 6 volts will barely spin the engine when you need to start it. Rather than change to a 12 volt system, I have been told I can use an 8 volt battery with no change to anything, to include the generator, lights, or voltage regulator. Can some one verify if this is correct.
JGarner
03-13-2008 05:52:19
 Re: case 300 question in reply to Kenneth Hevner, 03-12-2008 18:49:28
When I was a kid and everything was 6 volts Dad ALWAYS ran 8 volt batteries to spin the eingine faster. He tweaked the VR up to charge at about 9 volts just as stated below. 8 volts will not blow your light bulds, but it will shorten their life but for bulbs that last for years what's shortening by a few months.
hobbyfarmerinwi
03-13-2008 04:14:32
I had the same problem.
Changed to 00 cables. Filed the paint and rust off where they connect then installed. I also put in a 6 volt, positive ground altenator.
Works great.
That did make a new problem with the starter show up, but I took that into a good electrical shop, they cleaned it up, changd one part (dont recall what it was) and now starts and spins like new.
Scott KY
03-12-2008 19:12:10
The biggest problem with 6 volt systems is using battery cables which are too small. If you have a good starter and size 00 battery cables your tractor will start fine with 6 volts. As far as an 8 volt battery it will be hard for your generator to keep it charged. It also may blow your lights.
Bill Lisbon
03-12-2008 19:08:47
I have done this. Check voltage that your generator is putting out. You may have to step up the voltage to 9 volts. You can do this if you have a adjustabe voltage regulator.
