VC Continental Engine
Gene Dotson
03-12-2008 18:24:44
Rebuilding the Continental engine in my 1942 VC. Originally a F124 and want to bore the block to use 162 pistons. Anyone ever done this? Got the sleeves out and will need to bore another 3/16 inch to use the 3 7/16 pistons. Do I have enough wall thickness?... Gene
Tom Railsback
03-12-2008 18:44:42
 Re: VC Continental Engine in reply to Gene Dotson, 03-12-2008 18:24:44
Gene: I don't have the answer to your question but wanted to let you know I found the governor linkage that was missing off mine. I had an old one that I was able to repair and then last night I bought one off Ebay.
Now, if I can just find where I wrote down the length of the rod from the pedal assembly to that linkage and I can put it all together.
Gene Dotson
03-12-2008 19:26:44
 Re: VC Continental Engine in reply to Tom Railsback, 03-12-2008 18:44:42
Hi Tom;
I will get a measurement on mine tomorrow morning. I am finally getting my interest back to my VC. Been almost 2 years since I put it on the back burner, so getting my interest to it.
This was basically a junk engine when I got the tractor. Had been apart for 20 years with 1 rod, sleeve and piston missing. Getting it pretty well cleaned up and now have to find a machine shop to do the boring. Should be a pretty good puller with 162 cubes... Gene
