david brown cropmaster
prairieboy
03-12-2008 17:46:40
have just purchased a david brown tractor I believe it is a 1955 vintage and known as a cropmaster , can't find serial number yet. can someone fill me in as to where I can find parts and information re history of these tractors? thanks.
prairieboy
03-14-2008 12:45:38
 Re: david brown cropmaster in reply to prairieboy, 03-12-2008 17:46:40
thanks for the help so far ,I believe this is a super cropmaster serial #spp10557 ,(second P is stamp with a different stamp ) engine # cag4/3/128 this numbers off the dash plate , what year? and anything else we can tell from this?
davebr
03-14-2008 16:30:12
 Re: david brown cropmaster in reply to prairieboy, 03-14-2008 12:45:38
That is a Prairie Cropmster, 1953, only made 600 of them so kinda rare. First serial # 10001 last 10600
Dave
prairieboy
03-13-2008 18:34:25
located in canada ,edmonton alberta thanks for the info.
davebr
03-14-2008 01:22:30
 Re: david brown cropmaster in reply to prairieboy, 03-13-2008 18:34:25
Try Huw Taris, he is near you. >Link
Dave>Link
richardinnz
03-13-2008 00:55:52
Serial number is on a brass plate on the dashboard, if missing then a casting date is cast on the underside of the trans housing. Cropmaster production ended in 1953, they have a single hydraulic lift lever on the right mudgaurd, the 25 & 30 series tractors that replaced them have 2 hydraulic levers because they have T.C.U. in the hydraulic system.
davebr
03-12-2008 19:08:56
If it is 1955, not a Cropmaster. Check this site out for any info you need Link
Where>Link are you located?
Dave Brown
Nebraska
