db 885
wr
03-12-2008 00:20:39
hydraulic filter under trans part number.local napa cant look up new to db tractors. filter damaged due to water
Steven Meckstroth
03-13-2008 09:19:34
 Re: db 885 in reply to wr, 03-12-2008 00:20:39
Hopefully you have taken care of the source of the water.
Number 1 cause of water in hydraulic/transmission system on a David Brown is bad shifter boots.
wr
03-13-2008 17:30:30
 Re: db 885 in reply to Steven Meckstroth, 03-13-2008 09:19:34
thanks for all the info just got tractor at estate auction left outside in the rain changing all fluids local case dealer doesnt stock filter for power steering k902187 or hyd. k920522 got it at a good price mainly will use to bush hog pasture if it works out this summer will look to add loader waiting on my manuals to adj brakes fix electical etc.
Steven Meckstroth
03-14-2008 14:35:54
 Re: db 885 in reply to wr, 03-13-2008 17:30:30
Recommend that you get some kerosene and flush the system. If nothing else, get an air blow nozzle with pick-up tube. Spray as much as you can of the inside of the transmission casting.
Make sure you have the 3-point hitch arms down when you drain the reservoir.
After you use it for a couple of months, check to see if the oil still looks milky. If so, you may need to change it a second time.
Good Luck
Steven Meckstroth
corey c
03-12-2008 05:31:15
you need a K920522 hydraulic filter from your local case/IH dealer. It does not come with the gasket you need to get it seperate
