CASE 510B TRACTOR
TIM HIBEN
03-11-2008 20:17:36
WANTED TO BUY A GOOD CASE BLOCK OR MOTOR, CASTING # G1000 FOR A CASE 510B , OR DOES ANY ONE KNOW WHAT ENGINE INTERCHANGES WITH IT?THANKS TIM
mEl
03-12-2008 03:17:07
 Re: CASE 510B TRACTOR in reply to TIM HIBEN, 03-11-2008 20:17:36
If keeping it original is not an issue , I'd look for a combine 188-201 if you want a gas engine. A 207 diesel will fit as well, you have choices. The 164 was a bit different from Cases usual wet sleeve design and are a bit harder to find. Don L has some parts as I was chasing some for a potential customer but then he dropped the idea of fixing it. Don is good to work with.
TIM HIBEN
03-12-2008 05:28:44
 Re: CASE 510B TRACTOR in reply to mEl, 03-12-2008 03:17:07
THANKS ALOT FOR THE REPLY , I WILL LOOK FOR A COMBINE OR WINDROWER, THE TRACTOR IS TOO NICE TO JUNK . THE GUY I GOT IT FROM TORE THE OIL PRESSURE LINE OFF WILL RUNNING THE BRUSHHOG AND DIDNT NOTICE IT,IT BLEW OUT THE STARTER SIDE OF THE BLOCK....THANKS
mEl
03-12-2008 15:31:29
 Re: CASE 510B TRACTOR in reply to TIM HIBEN, 03-12-2008 05:28:44
Hey Tim, I may have led you down a wrong road, does the 510 have a 2 or 3 bolt starter on it , the later engines including the combine engines have a 3 bolt and the blocks are different in that area, sorry about that , i got ahead of myself, guess I should get my coffee before sitting down to type in the AM. mEl
