D C TOM
Garett
03-11-2008 18:13:14
This message is a reply to an archived post by dctom on December 15, 2007 at 03:55:33.
The original subject was "Re: D C TOM".
Hi DCTom,
Wondering if you can work your serial number magic on my old DC-4. 5619344DC. I think it's a 1952.
Thanks, Garett
Garett
03-12-2008 16:11:25
 Re: D C TOM in reply to Garett, 03-11-2008 18:13:14
Thanks!
Do you happen to know how to set the clutch on these? Mine has got the hand clutch, and I understand they are a over-centre style. But it doesn't 'snap' into place. I have the side cover off but can't seem to figure it out.
Tom Railsback
03-12-2008 18:08:30
 Re: D C TOM in reply to Garett, 03-12-2008 16:11:25
Garett:
I wish I had a scanner so I could scan and send you the instructions in the operator's manual; they show a picture of the clutch and the tool you should have to adjust it. The tool is basically a piece of 1/4 inch rod ab out a foot long with about 2 inches at a 45 degree angle. It is used to depress a lock pin on the clutch after which you turn an adjusting collar counter-clockwise.
I just remembered that I have an extra reprint copy I can send you. Email if interested.
Tom Railsback
Garett
03-12-2008 18:18:41
 Re: D C TOM in reply to Tom Railsback, 03-12-2008 18:08:30
Thanks for the help. I was on the CNH website and found a parts breakdown - I think I found the pin you're talking about. I'm going to try and build the tool as you described. I'll let you know if it works!
Tom Railsback
03-11-2008 18:21:58
Tom no longer has the build cards; please contact Rich Tworek at CNH.com
