ComfortKing tachometer
INCase
03-11-2008 05:52:25
Has anyone had any luck getting one of these repaired resonably? Mine works but the needle is broken off. They look like they"re sealed up. I talked to Roger Hornbacker but he said he doesn"t work on those. Thanks.
INCase
03-12-2008 09:04:13
 Re: ComfortKing tachometer in reply to INCase, 03-11-2008 05:52:25
has anyone taken one of those apart? Is there a trick to it? I may be able to get our local clock guy to solder a new needle on if I can get it apart.
Country Nate
03-11-2008 07:12:36
In Antique Power magazine there is an ad for tach repair. The name is Metro Speedometer LLC. # is 1 (816) 478 0116. They are in MO., and I know nothing about this outfit other than seeing their ad.
When I purchased my tractor it had a seized up cable that apparantly wore down the gear drive in the distributor. I had to replace the distributor and get a new cable. Hooked all that up and was fortunate that my tach still worked.
Good luck with yours.
CN
