Case VAC
The B killer
03-10-2008 13:49:54
Will a VAC make a good 3500-4000 puller.
Augie
03-10-2008 20:37:46
 Re: Case VAC in reply to The B killer, 03-10-2008 13:49:54
3500 yes, 4000 no unless you add some cubes to the motor.
Ours was making an honest 33hp from 139cid. That won't get it done in the 4000 on D2 tires
VACLee
03-10-2008 20:28:21
We pull our's from 2700 - 3500. We were going higher but with 13.6/36 tires we got tired of replacing bull gears. Power was not a problem, but we are not quite stock. I think the axles flex internally to much to handle much heavier than 3500.
Jim McVay
03-10-2008 17:52:16
I pull my grandafthers 52 VAC-12 in 3000# class in Florida with a close to stock engine and never run out of power. 12.4x 28 tires.
mEl
03-10-2008 15:03:14
On tracks that are sticky and take lots of power the VAC will be way short of power at 4000, marginal at 3500. If you get good pulling tires and get hooked up you will need 40+ HP. our guys use 14.9s and are short on power with a strong stock block engine in the higher weights on some tracks. mEl
