Hydraulic Fluid
Mike Rattan
03-10-2008 09:12:46
I bought a Case 431L out of a field yesterday. I am tractor ignorant but I put a battery in it and it started !!! It has three shifters on it and the one on the left makes it take off, but the clutch doesn't disengage it???? The PTO works but the three point won't raise up, if I am moving the right lever. Can you guys help??
C. Amick
03-12-2008 09:24:44
 Re: Hydraulic Fluid in reply to Mike Rattan, 03-10-2008 09:12:46
I have a Case 300 and don't know how similar it is to the 430. Here is how things are set up on my tractor: When the lever on the left is raised, it should stop the tractor wheels, but allow the PTO to turn. With the lever down, the foot clutch should stop both the tractor and PTO. The hydraulic pump is under the gas tank on my tractor. It has a rod located in front of the gear shift that you push and pull the rod to engage it and disengage the pump. The lever to the right of the seat should raise and lower the lift arms, if the pump is running. The pump uses the transmission as a hydraulic reservoir. There should be a plug with a dipstick mounted to it beside the gear shift.
