case D
frank van den d
03-10-2008 06:29:38
we have 1939 case D.with a base mount mag.how does one adv the timing?thank u.
Arthur
03-10-2008 08:09:23
 Re: case D in reply to frank van den dorpel, 03-10-2008 06:29:38
You should be able to rotate the round end oposite the end where the plug wires are. It will only rotate a little, about 1/8th of a turn. Thats if you have a case mag...Good luck Art
03-10-2008 17:24:17
 Re: case D in reply to Arthur, 03-10-2008 08:09:23
thank you.do u mean the drive end of the mag?yes it is a case magneto.
Arthur
03-11-2008 03:33:25
 Re: case D in reply to frank van den dorpel, 03-10-2008 17:24:17
Right above the impulse drive, is where you hook up the wires...The other end is where the points are located. There is a metal retaining strap that holds the cover to the points on. This cover is whar rotates a little to advance, or retard your spark. Good luck Arthur
