Carrier assembly for 930 6 speed foot clutch
Travis M
03-09-2008 14:48:30
I need a carrier assembly A21838 for a 930 6 speed foot clutch, also a Camshaft for same tractor.
Email me if you have something
Thanks
DKase
03-09-2008 17:47:30
 Re: Carrier assembly for 930 6 speed foot clutch in reply to Travis M, 03-09-2008 14:48:30
I should have everything you need in a parts tractor out in the trees. I start calving this week so I do not have much time to pull parts out. I am in East Central SD. Holler in I can help. DK
Thad
03-09-2008 15:17:20
Travis sounds like you are getting started on the old beast. Ive probubly got a cam not sure about the other. I will try to check tomarow. Are you wanting a gas cam? I cant beleive i got it to start and actually run. Thad
TravisM
03-09-2008 18:03:40
 Re: Carrier assembly for 930 6 speed foot clutch in reply to Thad, 03-09-2008 15:17:20
Thad,
I need either a gas cam or an LP cam. I think that other piece may be hard to find. I can't believe it runs either. I started it up when I got home just to see it run again. The block is in to the machinist we are getting started. You were sure that the block we got from you was out of a 6 speed tractor right. I just was going to double check on my parts CD, but I can't find that part number in any of the 930's. Let me know
Thanks
