Changing the oil on a 1594 with cab
RD TX
03-08-2008 13:01:02
Can someone tell me if you have to take to hood off to add engine oil? It looks like an oil spout at the top of the engine. I see one in the back but it is going into the rear differential housing. I think that is for the transmission fluid.
Thanks in advance,
RD
richardinnz
03-09-2008 01:33:12
 Re: Changing the oil on a 1594 with cab in reply to RD TX, 03-08-2008 13:01:02
There should be a filler cap on the front timing cover on the left side of the tractor I think. If the filler is at the top, then the bonnet on those tractors opens up, tilting to the rear on early tractors and to the front on later tractors, there should be no need to remove it. The filer for the trans/hydraulics is at the rear, there are also level plugs in each of the reduction housings, and the power steer pump which is on the right side of the engine.
