Information on Case tractor
MurrayE
03-08-2008 10:55:00
Recently purchased a CAse tractor, Serial # 4714640 D 1, according to the information it was manufactured in 1943. Any information on this tractor would be appreciated. At present time it is not running. Cheers, Murray
Alan Golden
03-08-2008 17:44:56
 Re: Information on Case tractor in reply to MurrayE, 03-08-2008 10:55:00
Murray,
It does sound like you have a 1943. If you email Rich Tworek at CaseIH ([email protected]) he can look to see if Case still has the original build sheet on that tractor. It cost me $7 to get a copy of the build sheet on my LA. Case does not have ALL of the build cards, but they do have some. It will give you all the details on model, date build, where shipped, etc.
Don Rudolph
03-08-2008 12:13:13
Murray,
According to the serial number you have a 1943 DI Case. It is the industrial version of the D series Case tractors. If it is truly a DI it will have a flat fronted radiator and grille, larger front tires, and larger rear tires, along with a special seat assembly compared to a regular standard D. Don
farmerron
03-08-2008 11:55:58
Model D tractor. Made from 1939-1953 Serial number range 4,300,001 to 5,700,001. Wt. 7,005 lbs. Bore 3.875" A large tractor.
