repair manual
mike from ohio
03-07-2008 09:26:51
I have a case 444 i have had 2 different supossed case dealers work on it costing me dearly.the seals keep blowing out of the drive motor therefore overfilling transmission causing leakage from relief valve. i plowed snow yesterday for hour and ahalf useing 7 quarts of oil. there are a couple of different valves under frame i am wondering if 1 of these valves could be bad causing excess pressure which blows out seals in drive motor.or if when drive motor when taken apart had some of the pieces nat alinged correctly causing 2 much pressure in motor. If you have answer to my question please respond. also can anyone tell me where i can purchas a repair manual for this tractor?. tractor model number 444-76.serialnumber 9726961.
Alan Golden
03-07-2008 19:38:28
 Re: repair manual in reply to mike from ohio, 03-07-2008 09:26:51
Try contacting Tom Peeper. His email is [email protected]. He collects and resells all kinds of manuals. There is a chance he might have what you are looking for, or be able to find it for you.
