1594
RD TX
03-05-2008 17:29:32
Can someone help me with changing the gear ratio on my 1594? I cannot seem to change the range. It appears to stay in the low range as I can walk fast and keep up with it in 3rd gear.
Thanks in advance,
Ricky
rickz
03-06-2008 09:36:21
 Re: 1594 in reply to RD TX, 03-05-2008 17:29:32
Rd:
first step-have someone operate the powershift lever and verify whether the linkage actually goes thru the four shift positions.There is a remote chance that something in the linkage to the powershift maybe unhooked or stripped.
2nd step-change filters as recommended by the other gentleman.The oil has to be drained to access the big suction filter below the trannie.Drain into a clean container and check to see if any filings or fatigued metal parts are present.Also change the cannister filter on the rear right side of the tractor.I would use new oil(hydraulic gearoil).Try the tractor when its dead cold -start in the highest gear and down shift when a good speed is reached.Then repeat when tractor and components are at operating temp.If parts are worn it may work cold ,and if something is failed it may not work at all in any condition.If these Poor-man's checks dont show anything The I+T manual has a pretty good section on the powershift repair, troubleshooting and rebuilding.The other alternative is hire someone to trouble shoot it.Also if your tractor is having difficulty moving in all gears but the low ones your clutch may be bad.It is worth checking that out.
mEl
03-05-2008 18:24:47
I can only guess from your description , but if it has the 4 speed powershift it will stay in low range even though the powershift lever is moved to another range if the supply pump is not getting oil to the control valve, the power shift defaults to low range, you need a professional to help you diagnose the problem, there is a port to install a gage to check pressure,as I said before we do not have much info and I am simply shooting from the hip !!!!!
RD TX
03-05-2008 19:09:59
 Re: 1594 in reply to mEl, 03-05-2008 18:24:47
is thre anything that I can check?
RD
mEl
03-06-2008 04:03:33
 Re: 1594 in reply to RD TX, 03-05-2008 19:09:59
Elmer, who posts here can help more than I. there is a screen for the power shift oil pump under the tractor , a big flat nut on the bottom of the filter housing under the center of the tractor, it could b plugged, you will have to check that, maybe a transmission oil and filter change would be a place to start. other than that theres not much external stuff to do. mEl
RD TX
03-05-2008 19:03:36
This seems to be what is happening. I can move the lever on the steering console and nothing happens. I just purchased the tractor. I think I may have mad a mistake.
