dc front hub to pressed steel
scman
03-05-2008 06:36:37
I have a Case DC with the large cast front wheels, was wondering if it would be possible to fit pressed steel on this tractor? Will the hubs off say a 00 or 30 series tractor fit on this axle? are the bearing the same on the inside?
thanks
Jim McVay
03-05-2008 18:11:10
 Re: dc front hub to pressed steel in reply to scman, 03-05-2008 06:36:37
I have installed 00 and 30 series 6 hole hubs on DCs. You have to change the inner brg on the new hub to have a brg with the DC spindle size. You will have to install a thin wall piece of tubing on the outer spindle brg surface to find a brg to fit that will match up with the new hub race. the seal is also a challenge. You will have to measure both a find a match. The width is narrow and some rims will rub. We use the 3 X 15 rims with 5.00 x 15 tires and it works.
Mathias NY
03-05-2008 11:30:41
Are you asking about using a rim with a stamped center on in place of the completely cast rims?
Case did have a stamped steel rim, essentially a miniature version of the rear rims. However the cast hub it not the same as the one used for the cast rims. They are also nearly as heavy.
scman
03-05-2008 13:51:23
 Re: dc front hub to pressed steel in reply to Mathias NY, 03-05-2008 11:30:41
I am asking if a hubs from the newer case tractor of the 00 series and 30 series tractor will fit on the axle of a dc. The hub and wheel both.
C. Amick
03-05-2008 08:59:51
Miller Tire may carry a wheel that would work (millertire.com).
Old Iron Larry
03-05-2008 08:49:39
I am putting an adjustable wide front on my DC and it has the metal rims. If it works I am going to put the hub and cast rims on the wide front and I will have the metal rims and hubs left over. According to the parts book the bearings are the same in both hubs and I have seen DCs with the cast rims.
grapefarmer
03-07-2008 08:44:31
 Re: dc front hub to pressed steel in reply to Old Iron Larry, 03-05-2008 08:49:39
I switch my DC3 to DC4 front. I mounted the solid cast wheels on the wide DC4 front. That worked fine, Now I have no idea if the newer 6 hole rims will work. If it does please let us know.
Thanks
-Dave
scman
03-05-2008 11:22:06
Old Iron Larry, I was wondering if you could find a casting number on the steel wheel hubs? if so could you post it? I didn't try a 6 bolt implement wheel, just didn't think it looked like it would work, but i guess i will give it a try. thanks everyone for your replies
J heitkemper
03-06-2008 19:12:11
 Re: dc front hub to pressed steel in reply to scman, 03-05-2008 11:22:06
I never thought about trying a 6 lug wheel either ,, Shucks
R Aiken
03-05-2008 07:39:48
I read on this fourn that a 6 hole implement wheel would bolt on a DC.
